1 - 8 of 8 Posts
Are you building the motor for boost or are you staying N/A?
Discussion Starter #4
i am planning on running a turbo later on but not for a little while. when i do turbo it i wasnt planning on running much boost maybe 5 to 8lbs
I'm running a supercharger with mine around 6 psi and I like those cams
A cam made to run a turbo is similar to a n/a cam, so you would be okay gettin like a stage 2 cam or stage 3, just depends on how big of a lope you want the car to have, I really like comp cams but I also like crower cams also
1 - 8 of 8 Posts
