1 - 8 of 8 Posts
Discussion Starter · #1 ·
I was driving home from work last night. Shifted 1st to 4th with no problems, went to shift into 5th and it was like it wasn't there. Had to push the shifter which seemed like double the travel than normal to get it into 5th. Then had to make a turn so back to 2nd, then went to shift to 3rd same problem as 5th and same when I shift to 4th. I only live a mile from work, it was 28° last night only let the car warm up maybe a minute. Not sure if that had anything to do with it or if there is a bigger issue at play. Any help or advice is greatly appreciated.
Sent from my XT1254 using Mustang Evolution mobile app
Discussion Starter · #5 ·
Just finished looking around in it. Was actually a loose bolt on the Steeda billet pro street shifter handle. Was allowing the shifter handle to move before it shifted. Thanks for the advice and help.
1 - 8 of 8 Posts
