I have a 2001 gt with 110000 miles I wanna cam it but will my 4.6 handle it ? I have intake exhaust headers and short shifter and staggered wheels let me know thanks
Yeah as long as its been taken care offI have a 2001 gt with 110000 miles I wanna cam it but will my 4.6 handle it ? I have intake exhaust headers and short shifter and staggered wheels let me know thanks
Valve springs, spring retainers, and adjustable cam gears.So it should be fine and what do I buy just the cams or do I have to buy like springs and all that ??
Welcome to modding. Nothing worth doing is cheap and it's all impossible to decide which company to go with. I think cams, cam gears, followers, and all that crap + install usually runs people around $1,300, don't quote me on that though.So all this sounds really pricey how much do u think it will be and wat kind of mpg do u get with cams
Aside from screwed up cam profiles, you shouldn't really have any issues as long as you have a good tune. The only issue I can think of comes from going too big with the cams and having to flycut your pistons because of oversized cams.Wow thanks a lot bud is there any problems I might run into after camming
Get stage 1 or 2 and make sure you replace all the springs, cam gears, and probably everything else that the manufacturer recommends for safety.So wat size cams are just the right amount of hp and not to big to mess up anything
This guy gets it. It's expensive, but doing it right the first time around makes sure that you always only have ONE oil drain hole.That's right I forgot the cost of the retainers and springs. I think it was approx $220 for the springs and I can't recall what the retainers cost, but I figured since I'm in this deep, I might as well get it done right.
