1 - 12 of 12 Posts
Discussion Starter #1
Ok car ran just fine never had any problems with it running yet. But I just went to leave on lunch and my car won't start? It will continuously crank over but never start??? I looked at my gauges and everything looked fine but oil pressure I notice its not reading any oil pressure.
Discussion Starter #3
When I went to start it the first time the gauge said normal pressure the the needle dropped and so now I have no oil pressure when I try to turn it over??? Note last night I noticed my fuel gauge was getting stuck? It read lil less 3/4 tank, then slowly built up to full tank. Note I also noticed that she has been consuming a lot of fuel lately...
I thought you said it won't start? So how can u see the oil pressure? Well any who .......... Fuel, spark and air! The three elements required to run a engine. Start looking at the three to figure what you're not getting. Good luck!
Discussion Starter #5
Yes gettin fuel checked out ok on gauge...
---------- Post added at 07:17 PM ---------- Previous post was at 07:14 PM ----------
I mean at very first when I went to go on lunch break it acted like it was gonna start and run read fine on gauges then everything just stopped. Well I mean not everything but car just cranks but won't turn over??? I need o2's real bad! Could this be playing a role in it???
Discussion Starter #6
sam minnick said:
I dont think it will read oil pressure until it starts... are you getting fuel
Yah I think your right but yes got fuel. It's gotta be something simple because it ran just fine and always has. That's why it just has my mind blown...
Check the fuses under the dash. Other than that im sorry to say its either of 2 things ....... oil pressure sending unit or oil pump
---------- Post added at 08:49 PM ---------- Previous post was at 08:48 PM ----------
Easiest would be move around the oil sending unit connection maybe it wiggled loose
Discussion Starter #8
You know I didn't think about fuses because I notice I had a tail light out and no cruise I forgot all about that...
Reset your fuel pump relay. In the trunk in the drivers side inside the interior panel. I bet that's it.
Yeah check the pump switch. As for the oil pressure, you might have a bad oil pressure sensor. They're about 12 bucks at autozone. Looks like this. At least for a 98 gt
Discussion Starter #11
Well guy sorry to disappoint you but the car started right up like nothin ever happened I don't know it was strange. She just started right up just a min ago thought...
---------- Post added at 11:44 PM ---------- Previous post was at 11:42 PM ----------
Wow that's cheaper than I imagined thanks for the pic and everything
---------- Post added at 11:45 PM ---------- Previous post was at 11:44 PM ----------
Oh and welcome! also great lookin car!
Wow that's great hopefully it stays like that. Good luck and no problem.
1 - 12 of 12 Posts
