1 - 8 of 8 Posts
Discussion Starter #1
I'm needing to tap my oil pan for my feed and return lines for my turbo ... I know I got to put the return line above the oil level for gravity ..how far up from bottom do I put the feed line?
You can feed off of the oil pump buy using an adapter, or taking out the plug (forget what size) and putting in a fitting.
you are correct about the return.
1 - 8 of 8 Posts
