1 - 9 of 9 Posts
Discussion Starter · #1 ·
I have a weird noise from 4th and 5th gear that is a grinding kind of sound. It doesn't do it when I am going slower. I only have problems with this noise when I am going around 55-60+. Any ideas on what this could be?
Discussion Starter · #3 ·
It doesnt do it when i shift. It is in the gears i guess. Shifting it is fine, it is while it is in the gear when it grinds continuously.
how longs it been since u had a clutch job...possible that ur throw out bearing went out,if not check ur fluid make sure theres no metal shaving in it...
Lorraine's driver
Is this grinding noise when your in gear moving, or when your putting it in gear?
1 - 9 of 9 Posts
