1 - 3 of 3 Posts
Discussion Starter · #1 ·
i just bought a 2011 GTI, with the Navigation. and i had 2008 mustang before and my stock sound system was beautiful on it. it had enough bass everything vibrated and shook. and sounded very well. the stock GTI system sounds horrible, the max volume doesn't even satisfy my need for loudness that's not ridiculous. I want a quality sound system that give it that extra "oomph" that will make me fall even more in love with it? if not what sound system do you use or recommend?
The Mustang might have had the 'monsoon' system, which is 500-1000watts depending on the option with a sub and proper amp. VW has decent systems for what they are, but comparing a 250watt to a 500/1000watt isn't the way to do it.
You're best bet is to check out a local sound shop and see what can be done. Keep in mind VW can cancel out on any comprehensive warranty repairs as they can say the bass of the new sound system was the cause of the problem... just FYI. I dealt with that problem with my '06 G6 GT. Apparently, the 12 disc CD changer I had installed in the trunk at a shop was the cause for my loose front speaker screws! Took GM 3 days and a piece of my right fist for them to install the proper screws.
Did you get the upgraded Dynaudio system? Or just the base system?
I found the dynaudio well worth the $360 or whatever it was last year when I bought my '10 Golf TDI.
1 - 3 of 3 Posts
