The install procedure appeared to be pretty simple ... were there any tough points, any tips to pass on or was it just insanely simple?
Installation was fairly simple.
Side Skirts are simple as can be, just make sure you clean them well so the adhesive sticks properly. I worked from front to rear and everything lined up perfectly with no issues. The only issue I had was with drilling the few holes in each one required for the extra clips, just be sure you get the car up high enough to get your drill in there.
For the front splitter, it was also pretty easy. I opted to remove the lower facia though, so I could flip it over and work comfortably on it on my workbench. You can install it on the car, but I thought this was way easier. I took my time, used masking tape to hold it in place once i got it lined up to drill out all the new holes, and it was simple. In my opinion, taking it off was worth the extra 20 minutes to get a flawless finished product.
You'll need to remove the fog light electrical connections, and the connection to the external temp sensor, which was in the drivers side top of the opening, and a phillips screw at each end of the bumper where it connects at the wheel well. Those screws were the hardest part for me.
I found that once removed the fascia will flop around a bit, so I put some towels around the ends of the bumper fascia as I removed and re-installed it to prevent scratching the painted part of the bumper.
I'm actually taking it back off again this week so that I can install my HID upgrade for the fog light bulbs I bought last week... so let me know if you guys have any specific questions or want pictures of any of it.
