1 - 14 of 14 Posts
· Registered
Discussion Starter · #1 ·
so i have been asking around trying to figure this out. Which will be better for the money and for the gain to the car: a new engine or a super charger???
and then...
what all do i need and how much will it cost??
and then...
should i try and install it or take it somewhere??
-Sorry for all the questions in one post but thanx for the help and advice
· Registered
10k? Where'd you pull that number from? You can get a 4.2l f150 motor and with some buddies have it in your car for <1k.
first of all, what year stang do you have. also, what are your future plans, budget and goal. if you have an older v6 it may be worth your while to go ahead and get another engine if yours isn't running great, or if it is, then perhaps a supercharger. need more information.
10k? seriously... there's an SC shortblock i could pick up tomorrow for less than 200 in LA (state).
· Premium Member
well it all determines if you have friends or not. Some people done have friends to give them great deals. If you use a shop to do all your work and get the parts you need for a engine swap the bottom price will be 4 to 5 K. If you decided to get a HiPerformance motor built and installed you aree looking at 6K up If you do it yourself 3k and up. You can find a used Supercharger kit kit ready to install for as little as $1300, I did or you can pay 3000 for a new one
· Registered
Discussion Starter · #9 ·
i got a 2000 V6
right now on the engine all i got is a MAC CAI kit
future plans depends on the money flow
but i want my exhaust, either a supercharger or V8, springs (getting in the spring), strut tower brace, tint (?), body kit, alarm, those are the major ones.
any suggetions on cheap ways to increase HP/Torgue let me know.
thanks again.
· Registered
you can find a used supercharger for a couple grand that'll have you putting out stock GT power. power isn't all the great without other modifications though to harness them. i mean, do you want 300hp but only your right rear tire spinning? probably not. you'd probably be happy with the basic bolt ons for now. a strut tower brace isn't the first step you should take in stiffening your stang... getting a take off rear sway bar is a cheap and easy mod, you might try that first. go to v8 websites, they are always upgrading to bigger adjustable sway bars and are getting rid of their old stuff for cheap. good luck.
· Registered
look into subframe connectors before a rear sway bar. that will join the two parts of the unibody structure and actually help lower 60' times as your chassis wont be flexing during launches
· Premium Member
2013 GT Track-Pack
10 fuckin grand... screw that i paid 2600 for my new 3.8 installed with labor and everything. 15 year olds need to get their numbers figured out
· Registered
I'd look into just building up the stock bottom end first and the get a blower down the road.
Use your current block and crank and then get a set of Ross or Wiseco Forged Pistons and a set of 94-95 Supercoupe Rods. Then get it assembed at a machine shop and your bottom end will be ready for some serious boost on a budget price.
1 - 14 of 14 Posts
