1 - 20 of 27 Posts
Discussion Starter #1
so i was on the freeway tonight and I went to shift into 5th gear... and ummm there was no 5th gear.. 8o!! I just recently installed a Pro 5.0 short throw so I'm gonna pull it apart tomorrow and see if maybe I did something wrong but all the other gears feel great... 8o
Banned
Maybe you set the stops to tight and it is not going completely into 5th gear?
Banned
Banned
you shouldnt use bump stops period, take them out
Why do you think that? :confused:
Older T5's are known to need them to prevent overshifting and bending the shifting forks.
Banned
Check your shifter boot and make sure it isn't bunching up and preventing you from getting the trans into gear.
Here's a link to a Pro 5.0 Shifter Install in case you want to go over the installation and double check the install.
Banned
I'm curious also. I don't use them as an actuall stop, but I just set mine a hair past where it goes when I shift.
That's exactly what you are supposed to do.
That way when you shift fast and hard they prevent you from putting to much pressure on the shifting forks.
I think some or maybe all of the newer transmissions have stops built in, but the older T5's do not.
Banned
any ideas on what I can do to save some cash?
Buy a service manual, tear it down yourself and see if it can be repaired.
That will save you a lot of labor costs at $70 or more per hour.
Discussion Starter #17
I'm over here in Roseburg, Oregon. thanks for the offer. If I need a new trans, or replacement probably be like a month or so before I can buy a new one. :)
Pete Jones
Did you try putting the stock shifter back in to see if you still didn't have 5th?
1 - 20 of 27 Posts
