1 - 15 of 15 Posts
Discussion Starter · #1 ·
So I noticed I have a scrape on the front end of my oil pan. This happened to me before so I replaced the oil pan and the front struts but it seems that its hitting the sway bar. Am I missing something here? And no I don't drive erratically but the city streets are bumpy but not a lot
---------- Post added at 01:03 PM ---------- Previous post was at 01:02 PM ----------
Posted a pic. Not sure if you guys can see it
It looks like the plug bolt isnt seating right. That may mean the hole was deformed. Check the plastic gasket on the bolt after draining the oil to see if it is damaged. If it looks ok and still leaks you will probably have to replace the pan to stop it.
1 - 15 of 15 Posts
