Is there any way to take out the oil pan to change it without taking the transmission out or using an engine jack to jack it up and remove the pan?
+1, when i did the cobra oil pan I droped the k member and placed the floor jack up under the bell housing and had no issues.Drop the k-member
You know the oil pan on a GT and a Cobra are the same right. The only difference is the oil pick up and the oil pump. I called Ford and verified the part numbers.southernstang00 said:+1, when i did the cobra oil pan I droped the k member and placed the floor jack up under the bell housing and had no issues.
Yup, sure do I just put Cobra in there because thats the only one I have done with the engine still in the car. My GT I did outside the car.You know the oil pan on a GT and a Cobra are the same right. The only difference is the oil pick up and the oil pump. I called Ford and verified the part numbers.
