1 - 3 of 3 Posts
Discussion Starter #1
Anyone know the life span on a factory oil pump? I'm going to change the seal on the pan and I didn't know if I should change the pump while I'm at it. This is on a 200k motor as well.
I personally haven't had a pump fail as much as the oil pump shaft from the distributor fail.
---------- Post added at 07:48 PM ---------- Previous post was at 07:48 PM ----------
My .02... If its jot broke, don't screw with it. Just clean it real good and it should be fine
Discussion Starter #3
Sounds good to me. Doesn't seem like a part to fail, I was just curious since I'll be down there anyway. Thanks for the suggestion.
1 - 3 of 3 Posts
