1 - 2 of 2 Posts
Discussion Starter · #1 ·
The casing around the headlights what would you all recommend to remove 4 layers of paint
Sent from my SM-N920V using Mustang Evolution mobile app
I assume you are talking about the fender extension and headlight door???
These were originally made pot metal and if damaged are really hard to fix.
I have always used Klean-Strip which is an aircraft paint remover. I used this on two 65/66 Mustangs and one car had 5 coats of paint. It took a couple of applications to get to bear metal though. Make sure you use it in a very well ventilated area and use a respirator that is rated for toxic fumes and solvents...also use rubber gloves and safety glasses and don't wear good clothes or shoes...after stripping to bear metal use a metal prep to prevent rust..IMHO
1 - 2 of 2 Posts
