1 - 4 of 4 Posts
Just make sure you get a low pressure, 6 lbs, pump for carbs and not a fuel injection pump.. the easiest place is on the fenderwell next to the old pump..you might want to get a blocking plate and remove the mechanical pump.... the power needs to come from the ignition switch so it goes on and off with the ignition..
You don't need a picture because you can mount it anyway you want. The is a definite in and out, but there is usually only one power wire, since the chassis mount is the ground.
1 - 4 of 4 Posts
