1 - 6 of 6 Posts
Discussion Starter #1
So I broke the plastic grommet elbow that comes out of the air intake tube going from the throttle body to the air filter box (Has a rubber hose attached to it). Anyone know if those are replaceable and, if so, where's the best place to get them?
Thanks, folks!! :bow:
Super Moderator
Yeah autozone sells them for like $3. Its a Ford PCV fitting.
Discussion Starter #3
Thanks for the quick response and lead on the part. There's no specific part number to fit correctly or just some basic bulk Ford 90 degree PVC elbow? I guess I can remove the old one and match it up. Thing doesn't want to budge which is why it snapped, I'll give it another go to get it out. It's for a GT350 intake tube. I did the Ford Performance Power package Stage 2.
Super Moderator
If its plastic just drill it out and use whatever plastic fitting fits.
PVC inlet break
I just tried and that thing is in there pretty tight, seems glued or pretty permanent.
I have the same problem as you with the pvc inlet on the throttle body side breaking off. I simply epoxied it back on as it was a clean break. May I ask what you ended up doing to fix this?
1 - 6 of 6 Posts
