I know there are a ton of questions about gears on here but I have a question for those of you who have swapped out the 2.73 gears for 3.73 gears. Did you also go for the posi rear or kept it simple? Thanks!
I feel like including LSD when you sell cars is a little unsafe... I mean seriously its gotta be hard to drive when your tripping ballsThey do come with LSD. I had 3.73 gears installed in mine. I ordered the 3.73 gears combo kit that came with the gears and bearing kit and tuner. It was real simple!
Right, I should have check that first. Thanks!I believe 2011 + have a tlok unit (same thing as posi by ford) from the factory. Not sure on 2012~
jack up car, rotate wheel by hand if the other wheel goes the same direction you have it, if it goes the opposite direction you dont.
