1 - 7 of 7 Posts
I've seen it done on mustangs, and it does look pretty good. I would get one if my antenna were on the priority list. Follow your antenna cable with your acc. line. I dont think that the low voltage emmits enough EM Radiation to effect the AM/FM signal strength. ;)
personally, i'd just take the antenna off... i only listen to cd's, so i have no use for it.. but then, there's the simple matter of the nasty gaping whole...
Someone makes an antenna delete kit. I think it's UPR or MGW.
Also, www.MustangTuning.com sells a 8" attenna for $20. You can also cut and modify your stock one to be shorter. There is a guide for it on www.MustangWorld.com.
1 - 7 of 7 Posts
