1 - 7 of 7 Posts
Discussion Starter #1
1ST POST for this Newbie!
Just got my 2012 GT 5.0 Premimum, 3.55 Axle, Candy Red, Saddle Interior...
My issue is a small, unimportant annoyance.
I'd LOVE to get some of your thoughts on.
My Interior LED ambient ligthing works great, all colors, all modes, in the door sills, door panels, cup holder, gauges, *rear* footwells.
HOWEVER the **FRONT** Driver & Passenger Footwell LED lights do not illumintate in any way. Ever. I crawled under the dash, the LED lights are there, and look to be 'plugged in'
Local Ford Dealer wants to charge me $111 diagnostic just to look at it, regardless of successfull diagnostic.
Thoughts Please?????
Thanks!
Jon D
Thanks!
Jon D
I'm sure someone will offer a solution. Personally since I don't know about that stuff I would look for a shop that Does lighting/stereo stuff. Im sure they could figure it out for a lot cheaper.
They are OUT. NO light ever. I can change thru all the colors, no light.
There is one 5/16 or smaller size cant remember holding it in place once is out of under the dash you will see the wire that plugs in to it make sure there is a good conection on it or if its even plugged in from there im not sure but it might be burned out only way to find out for sure is takeing the ones on the back out and pluging the front ones to see if light up if it doesn't then they are burned out intead of paying dealer over $100 just to tell you i would just get the part number out of the front ones and order 2 from dealership they have to be less that $100 for sure and replace them odd thing is that both front went out same time now this its all info from my 2013 not sure if 12 was same maybe they got disconected somewhere else while servicing somthing else and i cant think of a fuse causing this since the rest work
Discussion Starter #6
Crawled Underneith. Followed the wire cables (way) back... They werent connected... I would say straight from the factory they were never plugged in because they were tucked up in there so high and clean that i couldnt even see the connectors until I fished them down.. I spoke to the original owner before me (1-owner prior) and he said he never saw those lights work...
interesting.
Thanks.
interesting.
Thanks.
Where u able to plug in the wires? If not i would take pics and take it to dealer and complaint if they dont help i would call ford customer service and complaint
1 - 7 of 7 Posts
