1 - 4 of 4 Posts
Discussion Starter #1
Car had trouble starting the last few weeks. Replaced alternator and saw improvement. I have a very rough idle going on. It will rev to 1000 rpm by itself n then a few seconds later drop back down. I've also had a problem with my stereo cutting out while reversing or when I punch the gas n get on it a bit. Also my lights are dimming when I brake or roll windows up and down or convertible top and it seems like things aren't working very fast for example the power windows roll up very slowly. Any ideas on this problem, places to start looking, tips to fix??? Ps this was all happening before I replaced the alternator. Also everything goes to working normal when I push on the accelerator. The stereo will kick back on, windows go up faster ect. Thanks for the help guys cheers
Lorraine's driver
Kinda sounds like you have a wiring problem somewhere. A loose or damaged connection. You should check you connections at the battery. Check battery wires too. Check the ground wire and where it connects to the frame. I believe there's a wire the connects to the engine for a ground as well.
As for the stereo, that could be loose connections with the radio. Is it an aftermarket radio? Was it recently installed or worked on. When you get on it, it could be shifting the loose connection and causing your stereo symtoms.
Since you replaced your alternator, make sure your battery is fully charged. ~12.6v is about where it should be. Some alternators will even tell you this in the instructions too.
Maybe it has something to do with the acceleration pedal like maybe a stripped wire that touches when not wot. Just a suggestion but like azure said check connections and possibley grounds that may be loose but go back to contact with the jerk of wot if that somewhat says something like it wiggles back in place. Sorry if i made no sense couldnt find how to explain it
1 - 4 of 4 Posts
