1 - 2 of 2 Posts
Discussion Starter #1
So i have a 2000 model v6 convertable with a aftermarket stereo and i was driving down the road and i see sparks flash under the stereo... Sterio stops working and also the speedometer lights... Fuse was blown but i replaced it and it still wont work. What do i freakin do?
your aftermarket radio probably grounded out and shorted out a wire somewhere...pull the radio out and check the back of it...usually there is a fuse back there as well. also loook at all the wiring for burnt coverings. then pull the cluster and check the wiring to it.
1 - 2 of 2 Posts
