I suggest that you keep a close eye on the coolant level, and the oil to be sure that it is not becoming contaminated with coolant.
I would also pull out the #4 spark plug and see if it is becoming contaminated with any coolant or motor oil.
The P0153 code could be caused by a number of things.... An exhaust leak, faulty wiring, a vacuum leak, faulty MAF sensor.
I would begin the diagnosis process by absolutely eliminating the possibility of a blown head gasket. If the gasket has failed, it could be the cause of both of the diagnostic trouble codes.
