1 - 3 of 3 Posts
Discussion Starter #1
Hello Everyone,
I have a 1996 GT 4.6 SOHC. Just bought it and have changed out all 4 o2 sensors and bought new gas cap.
I'm still getting the 1443 code, I did buy a new purge valve solenoid. Can anyone help me with the location of this part.
Thanks
Drew
For what it's worth, I found this info on another forum...
I replaced two parts (little cans just underneath the headlights.,.
easiest way to get to them, jack up car, remove front passenger tire, and unscrew/pull back the lining, and you will see it right in front of where the air silencer used to be..
these two part numbers fixed my cel with P1443
E6ZZ-9C915-A (Canister Purge Solenoid) and
F57Z-14A606-BA(Thermistor/Flow Sensor)
one of them is like a little valve with an electrical connection, and the other is a little canister looking thing, u will also want to purchase like a foot or two of vacuum hose because the one in there will be all dry rotted and old.
like i said, that is what fixed my P1443 Cel code
Discussion Starter #3
Purge Valve Solenoid
Thanks for the quick reply, I will pull that wheel of tomorrow and I will let you how it goes. Thanks Again!!
Drew
1 - 3 of 3 Posts
