1 - 5 of 5 Posts
Discussion Starter · #1 ·
So my car coded and I went to autozone to get it checked out. Came out saying that my purge line is blocked and the most common fix for our cars when that happens is the purge valve. Anybody have that issue before?
2012 Kona Blue MCA Cyclone
AIRAID CAI
4.10 gears
Ford Racing Axle Backs
'Unknown Tune'
Yea my car was throwing a code saying there was a small vacuum leak. I went to rock auto and bought the new purge valve, I took the old one out and saw That the gasket was worn out, then put the new valve in cleared the code and it has been good since, and this was a month ago. I did read that this is the most common problem with all fords. I how this helps you.
Discussion Starter · #3 ·
That's what I figured it was. How invasive and/or difficult was the replacement?
AIRAID CAI
4.10 gears
'Unknown Tune'
It was very easy, the location was close to the throttle body and the part was 25 dollars. Here is the best picture I have of the valve. ImageUploadedByMustang Evolution1477328271.018772.jpg
Here is a picture of the part you are going to need. All you need to do is disconnect the vacuum line and the wire harness and Unbolt the two bolts on the top. It comes with a Blue gasket as you can see on the bottom. The gasket on mine went which cause the small vacuum leak. ImageUploadedByMustang Evolution1477328667.923977.jpg
1 - 5 of 5 Posts
