1 - 5 of 5 Posts
Discussion Starter #1
Alright so I am looking for a fun project for the spring. I already have a Mustang daily driver and a show quality one but thats besides the point. I am looking into buying a Mustang, possibly a roller, and dropping an 03/04 Cobra motor into it. The question is can I do a direct swap with a V6 of that gen.? Or would it be easier to swap with a GT?
The swap would include every part of motor and tranny, and all needed electrical wiring for the engine to function.
I would like some input/advice. I'm hoping someone with more knowledge than I can tell me I can use a V6 because I could find one a lot cheaper and sell that motor and tranny.
No haters please.
you have a lot of options,
1 - Thunderbird 3.8 supercharged $400 in salvage yard,
2- http://www.3.8mustang.com/wiki/Main_Page
3-Coy Miller Engines
450 hp 3.8 engines
http://www.coymiller.com/program/program_sc_stage2.htm
4-Steeda's Supercharged V6
QS6 4.0 SOHC
http://www.themustangnews.com/carnews_07/st-1207qs6.htm
5- 05 Mustang 4.0 CS6 $8k
6-Turbochargers
see the new remote or rear mount turbos
http://www.ststurbo.com/
7-Turbocharging a Legend
4.0 SOHC 350 to 450 HP
http://forced4.com/v6project1.html
8-2007 CS6 and CS8 MUSTANGS
YAHOO GROUP
http://autos.groups.yahoo.com/group/SHELBYMUSTANG/
9-2007 V6 4.0 build up
http://www.v6power.net/vb/showthread.php?t=29129
10-CS6 Shelby
http://forum.shelbyautos.com/index.php?showforum=6
Shelby CS6
http://www.shelbyautos.com/cs6.asp
and these are just the 6's
If you're going to build a Cobra, start with a GT
Different struts for the added weight, different brakes for the added power and weight, different motor mounts and may have to be relocated, are just a few things tghat pop to mind.
Not hating on the car.
Hating on the project.
You're going to spend more money on the swap, than just buying a Cobra in the first place.
What would the point be? Just to say you did it?
Not worth your money. If you were to put the supercharged 4.6L from the 03-04 cobra into a v6 body, you would have some issues. First, the v6 tranny would not be able to handle the increase in power from 195HP to ~390HP. So, a trans upgrade is a must. Also, you would have to weld in the new motor mounts because the v6 ones arent in the same places. You would have to swap out the entire rear to handle the extra power as well. The entire exhaust would have to be done. Also, upgraded suspension to handle the extra weight from all those new parts. Plus the fact that the v6 frame probably wont be able to handle the double in power.
Save yourself tons of money and A LOT of time and just buy a cobra
1 - 5 of 5 Posts
