Has any one had this issue 58 k , dealer is replacing seals braces a replacing all moving parts in the differential is this normal 17 gt premium. Be blessed.
No. It's not normal for a transmission or differential to start leaking after only 58k miles.
I presume that there must have been something besides a leak, for them to replace all of the moving parts?
Hello all,
i began hearing a grinding noise when i turn my car on and it runs on Idle. The sound can be heard best when you put your ear next to the Shifter.
It almost sounds like gears grinding together. It comes and it goes and it is also heard at times while driving.
i am thinking it may...
Mine is a 99 Mustang GT 5 speed I bought a Bama tuner off of my uncle is was a 04 Mustang GT 5 speed as soon as we flashed a map to my car the 99 hasn't started since it will crank over and sputter but not getting fuel fast blinking that fly and immobilizer code on DTC someone help please first...
So I have a 16 Mustang GT auto transmission and have on two separate occasions had issues with my transmission. From a parked position (while the car is running) and shift it into reverse, the transmission feels like it’s in neutral. Then shifting it into drive from reverse still feels like...
Just wondering about the rear panel that where damaged. I was going to buy a new door frame and move the guys over since the shell was the only thing damaged. Is this panel something I should just let a shop handle?
