1 - 1 of 1 Posts
Discussion Starter #1
I know there are a lot of kits out there but a buddy of mine said I can do it really cheap using a bracket to mount the calipers, any caliper that'll work with the mount, the disk, and an object called a hat. The hat slides over the studs and you bolt the hat to the disk. You then weld the brake caliper mount and bolt the calipers to the mount according to the position of the disk. Can anyone tell me the pros and cons to this as well as if its worth doing and how safe it is? Thanks
1 - 1 of 1 Posts
