What brand/type lower control arms?So I installed some rear lower control arms and now my car has developed a thumping sound whenever I shift, leave a stoplight or stop sign, and if I tap the gas you can hear it. It's definitely coming from the rear. Any suggestions?
Did you replace the upper? Also did you grease the bushings?BMR poly bushings. I tightened everything. I even checked for play in the control arm. Solid as a rock
They're greased. No I didn'tDid you replace the upper? Also did you grease the bushings?
Maybe the upper is loose or has a worn bushing. Could you have a bad shock that's been exposed by the stiffened LCA.They're greased. No I didn't
