1 - 9 of 9 Posts
Discussion Starter #1
So i was replacing all the gaskets on my 302....i was gunna go ahead and replace the rear main seal but im not to sure on how to....am i supposed to remove the crank or the seal holdin the cranks down or can it be done strait out tha bak? Help me out
Discussion Starter #4
Got tha block out nd took tha flywheel off....i see tha seal but is there a way or technique to get tha seal out without having to pry it nd risk damaging tha crank snout?
Take a small diameter sheet metal screw and thread it into the seal, not too far though. Then just use a small crow bar or pliers and pry it out.
1 - 9 of 9 Posts
