1 - 11 of 11 Posts
· Registered
Discussion Starter · #1 ·
I am rebuilding my 302. The motor was not blown or messed up. I'm goin to fresh in it up and put new intake, heads and cam. Do I need to have the block machined ? Or can I just rering , gaskets.. etc . then reassemble ?
· Premium Member
If you are putting new heads on and have the extra funds I would at least recommend having the block checked and possibly milled to ensure the new heads have the best possible mounting surface
· Registered
Just my opinion, but I say hone em! Anything to save headaches down the road.
---------- Post added at 02:18 PM ---------- Previous post was at 02:15 PM ----------
No need to send to a machine shop to do this. Buy a speed hone, slap it on the end of a drill, and put you some nice cross-hatching in it.
· Registered
It should only take 3-5 strokes in the cylinder walls with the hone
It needs to be done so the new rings will seat properly. Honing is just for getting the glaze off the walls. Nothing complicated! Good luck!
1 - 11 of 11 Posts
