1 - 20 of 22 Posts
Discussion Starter · #1 ·
well with unsuccessful attempts to ask over at rustangworld and getting -------------take out the windsheild or yank real hard comments......ill try here.
how do you remove the rearview mirror from the windsheild the correct, safe, human way? its not mounted the same as others i have seen which have a bolt in them.
thanks!
Discussion Starter · #3 ·
wow...really.........is it easy.............can you use a screwdriver? i mean leaving the button on the windsheild.and just removing the mirror itself.
well, mine comes off really easily. just drive for a while and it moves itself loose. POS isnt glued to the button anymore.
anyway, best advice would be to use a small hammer and a screw driver. just put it b/w the button and the mirror and slowly tap. it should break the seal and then it will slide right off
no, mines not held in by a screw. mine slides off. just take a screw driver and gently tap it up and off of the window button
Discussion Starter · #11 ·
ok so the screw driver goes into the hole type cover at the bottom of the mirror mount then and it taps off.....ok i thought it might have been a cam lock mounted mirror..........but i think it is a wedge mount... thanks i will try that...
Discussion Starter · #12 ·
Discussion Starter · #14 ·
yes that was my next guess..........seeing winter is here in ny..i will have plenty of reading time..........but dint think that it would have something as simple as a rearview mirror..............guess its not too simple seeing i couldnt get it..
I am strangely drawn to your avatar. Would make a nice updated mascot for Wal-Mart.
"Slashing prices, showing juggies. We want to make our customers feel welcome at Wal-Mart!"
Tin Kicker
OOOOOhhhhhhh......
By day she's a greeter, but by night, sexy sixty-five year old Mildred is a dangerous dancer at a local tavern...slip a dollar in her bikini and watch her swing...like pendulums on a clock.
"Hey, man, she's not that bad with the lights turned down!"
"Dang, dude, you thought she had four arms! Those ain't arms!"
"Man! She just got my foot with one of 'em!"
"AAAAAIIIIIIIIII! Run!!!" :shock:
Tin Kicker :headbang:
Tin Kicker said:
OOOOOhhhhhhh......
:no: After reading that, I feel I have to take a shower. :oops:
Discussion Starter · #20 ·
just so we all know
to remove the rearview mirror you need to take the mirror face and push it down and then gently apply pressure to it in order to pop the mount loose. all it is held on with is a clip that secures it to the window wedge.
1 - 20 of 22 Posts
