1 - 4 of 4 Posts
Discussion Starter #1
Like it says when i turn all the way to the left the driver front tire inner rim and tire grind on the arm. Its been doing it since i got the car but is finally bug me enough to try and figure out what might cause it and if i can adjust something to stop it? It does not do it when turned all the way to the right only left. Car is a 94 gt
Thanks
As said above, my rims are 17x9's in the front and rub on the steeda sway bar.
I have the rack limiters wich were purchased at my friendly local ford dealer.
haven't put them in yet been lazy. You could also use a small wheel spacer, I
did this on my 90lx with 17x9 04' cobra wheels up front...
Discussion Starter #4
Ok thanks i was going to do a New K member and tubular a arms with my new motor in the spring so i hope that might fix it
1 - 4 of 4 Posts
