This!!!!!pwrby4d said:They all do it. I had my last rear out of the car and painted it with rustoleum hammerite and it held up fine.
You can get that rustoleum hammerite paint in a can and put the car on a lift and do it easyn with a brush if it bothers you. We did a friends car that way. Cheaper than POR15 and looks really nice when done.
I plan on painting this one too when I get the time. The rust will actually help the hammerite bond so you just need to brush off the loose stuff.
Ya that is a breather valve. I guess to be safe you could check the fluid level. The cap is located on the drivers side up top. Take the top off with the car level. It should be full and if you stick your finger in there some should come out. If not, add fluid until it comes out. The rear axle tubes are not sealed from the diff housing.Mine is rusted too and has either grease or oil coming from this little nub on the passenger side. Breather valve maybe?
Could it be the reason I'm having some weird popping noises sometimes in the rear end?pwrby4d said:Ya that is a breather valve. I guess to be safe you could check the fluid level. The cap is located on the drivers side up top. Take the top off with the car level. It should be full and if you stick your finger in there some should come out. If not, add fluid until it comes out. The rear axle tubes are not sealed from the diff housing.
Before you do that though you it wouldnt hurt to put a rag over the breather and get some of whatever is coming out and smell it to diagnose if it is gear oil or just grease.
Well the popping noise is probably just driveline noise between the driveshaft, pinion and trans.Could it be the reason I'm having some weird popping noises sometimes in the rear end?
Pep Boys (at least out here anyway) will rent a lift hourly. It would not take more than a half hour to paint it with a brush. The hammerite dries really quick and is tough too.Well, From what I have been told: The axles are made of cast iron and will have that surface coating of rust but it does not affect the integrity of the axle.
It sure does not look nice at all on any car let alone a Ford Mustang.
I have heard on the MCA forum that the dealers will paint the axle if you complain enough. The only problem with that is that the person they let paint your axle will probably paint the inside of your wheels and everything else that don't need overspray on it.
I sure don't want some idiot turned loose with an aerosol spray can under my car. I guess i'll just live with a rusty rear axle.
Unless the pulley is billet aluminum like mine.Red Stallion 11 said:Rear end, pulleys, etc rust on these cars. Normal
Yes I've got it on my 06. It came from Maryland, so I'm sure that had something to do with it. But I completely agree Ronnie.ronnie948 said:Does anyone else ever notice a very rusty rear axle on their Mustang. I grant you it is only surface rust but it is not to nice looking.
I'm wondering if anyone else has this rusty rear axle thing going on.
