1 - 20 of 47 Posts
· Premium Member
Discussion Starter · #1 ·
So I lowered my stang about 3 weeks ago, I let it settle and when going over 40 it began vibrating bad so I figured alignment. Got it done today and it still shakes but not as bad and now at around 55 and over. What else could the problem? My friend said it could be the driveshaft. Thanks for any input
· Registered
Is your steering wheel vibrating badly?
· Registered
As stated above, try to give us more details on the vibration. Is it coming through the steering wheel directly or more through the whole body?
There's a good chance the vibration is caused from a poor driveshaft angle. When you lower the ride height, you lose a good bit of the angle, depending on how low the springs are. Without the proper angle, you'll feel extreme vibrations through the whole body of the car, coming from the driveshaft.
Hope this helps some!
Shane
· Registered
I had the same issue... Had 3 different shops balance my tires and check my entire suspension to see if I was maybe missing something... Turned out one of my rims had gotten bent slightly. Everytime they balanced my wheels, it came back just at a different speed until I replaced my rims. Drove me crazy...
· Registered
Mine started right after I lowered mine with the H&R SS springs and the MM caster camber kit. While I was at it, I replaced my shocks and struts also. I went crazy for months, chasing everything down... I finally told my wife that I was sick of the vibration and I was ordering new rims and tires and if that didnt fix the problem, I was getting rid of the car. lol...
Yeah, if you get a road force balance, you should also get a printout that will show you everything.
BTW if it's in the steering wheel, it's from the front, and if it's in the seat, it's usually from the rear. Mine was bad in the steering wheel and my front driver side rim was the one that was bent.
Good luck.
1 - 20 of 47 Posts
