1 - 2 of 2 Posts
It's possible, sometimes when fluid or water gets between the belt and pulleys the pulleys can spin under the belt causing the ribs to get deeper then normal. If its only been a short time this may not be an issue. I would clean the belt up and try it, if the belt is damaged it will likely make some noise, maybe not right away though. Belts don't cost a lot, I would suggest changing it to avoid any issue at all. Just my opinion though.
1 - 2 of 2 Posts
