1 - 13 of 13 Posts
Discussion Starter · #1 ·
Help...The 'Service Engine Soon' light came on this morning - car sounds/acts just fine. This happened about 6 months ago (of course, the car was still under warranty then - it is NOT under warranty now) and a sensor (fuel sensor? I forget, really)was bad and was replaced.
I'm figuring the same thing has happened since I understand there is an issue with these sensor things. I am wondering what to do with it since dealers look to screw people once the warranty is gone.
Any suggestions would be GREATLY appreciated.
Val
You want to **** me?
yeah what laser said... theyll tell you possibilities of what it might be, then take it to a shop that specializes in your problem. Autozone wont do the work for you, theyll just tell you possiblities of what might be wrong. Also, what they tell isnt necessarily whats wrong ;) just dont take it to a dealer... youll feel like you were just manhandled by the hulk after a visit to ford lol
Discussion Starter · #6 ·
I wonder if disconnecting the battery would make that freakin' annoying light go away ;) Is it even worth a try?
I wonder what cars did before all these "gizmos" were added to them to tell us they have a fart cross-ways.....they acted/ran just fine without all that BS, that's what. Just my .02 on that.......
Discussion Starter · #8 ·
Resetting the CD/radio shouldn't be a problem - it gave me fits when I first got the car and I'm surprised I didn't run into something.
I saw somewhere that -sometimes- (probably not too frequently) if you disconnect the battery for 15 min the light goes away (for however long).
The car runs/acts just fine - which, makes the light and subsequent expense pretty f---ing annoying, especially right around the holidays and ESPECIALLY since I had this done not 6 months agon :oops:
Yeah, you can reset it by disconnecting the battery, I would step on the brake pedal 3 or 4 times after disconnecting it, and leave it disconnected as long as you can without causing yourself a problem, I usually do mine overnight if I can, then drive for 20 miles or more non stop on restart to give it all time to reset itself. It is a good idea to take it to autozone for a code read though, its free, no cost at all. The repairs, if necessary, can be done after Christmas.
Fancy Autozone things??? A code reader maybe? What did this fancy thing cost?
My light came on a while ago too. I took it to AutoZone and they told me it was
1. cylinder #1 misfiring
They recommended changing the plugs and wires so I did. I later took it to a shop who checked the actual spark going through the wires and they figured out it was a bad coil pack.
1 - 13 of 13 Posts
