1 - 14 of 14 Posts
Discussion Starter · #1 ·
i have a 2004 3.8l auto and i was rading about shift kits on here. People say go and get one but i needd to find one and where! and how . . . basically i dont know jack about it . . . plz help me on this. Where can i buy one? how much? is it worth it? etc etc etc :confused:
WhiteStang99 said:
google is your friend. ;)
geez your a mod and thats all you could say :disgust:
dont get a valve body shift kit its a waste of money imo, there are shift kits out there that can actually do some good but not the ones that just **** with your valve body. some shift kits make you change some of your planetary gears and pump gears but there isnt one out for the 4r70w
just get a tranny cooler from summit racing.com or jegs.com
go to that link find the tranny you have then check to see if it have jerry mod next to it click it then , it shows you how to do the jerry mod
wtf are you talking about?? My b&m valvebody improved how my trans worked 100x over stock. Stock slow sloppy shifts are pathetic...
get a good shiftkit (ie jerrymod, b&m) and you'll be MUCH happier.
those shift kits just **** up your acumalators, there are better tgings to do to a tranny than a valve body shift kit. all they do is make the shift firmer and shorter thus ****ing up your acumalators.
and what's different between the b&m shiftkit and a jerry mod shiftkit???:wtf2:
When my chip was burnt they changed the rev limiter and added line pressure to make a firmer harder shift I have a 2600 stall too. my trans is just fine and i run high 13s in my v-6. My sugestion is if you plan on haveing a chip done let the computer change your shift points, line pressure and move the rev limiter up to 6000 -6200 rpm.
my trans is stock except for the stall. a stall will be good for 3-4 tenths and you can get one for about 400-450 at EDGE RACING and a chip can be burnt or flashed for about 200-300 bucks.
exactly make a chip handle all your changes, not some cheap valve body shift kit
1 - 14 of 14 Posts
