I'm installing these myself.. I already have the seats and body panels out.. But the directions are confusing as hell. Someone help me out. Please.
Materials:
10/64 bolts (6)
¾ Double Side Tape
Adhesion Promoter
Rubberized Undercoating
Where the hell can I find 10/64" (5/32) allen head bolts? I've been to like 3 hardware stores and the smallest they carry is 5/16". And those weren't even allen head. They were hex head. Where can I get these? Or, alternatively, what else can I use?
The same goes with the 3M 3/4" Tape.. Haven't found it at any hardware or auto store.. It's either 1/2" or 1"... And I think they rate the tape based on stickyness.. What should I use?
The adhesion promoter... I found that. But it says it's for paint adhesion.. Since I'm not painting anything.. What good is that?
Here are the directions I'm confused with:
Step 1: Clean area with prep-solvent
Step 2 : Mask area and under coat
Step 3: Clean tape area of paint and primer residue with lacquer thinner
Step 4: Clean area again with prep-solvent
Step 5: Apply a coat of adhesive promoter
Step 6: Apply double side tape to cleaned area
Okay.. So I prep... Mask the painted areas... Undercoat the unmasked area.. Then I use lacquer thinner on the undercoat? That makes no sense... Then I put down a coat of adhesive promoter and then put tape on top of that? Huh? This really needs pictures.
Somebody help. I know someone here knows wtf he's talking about.
Materials:
10/64 bolts (6)
¾ Double Side Tape
Adhesion Promoter
