1 - 6 of 6 Posts
Discussion Starter #1
Does any one have this? Easy-ish to install? Keep the water pleasant?
Our pool is 56 degrees - unless you've had WAY too much to drink, its pretty freakin cold :shock:
Pool?
What's a Pool? That green thing with the balls on it you try to hit into the corners?
I had this. It worked good. It works 50x better if you have one of those bubble pool covers to keep the heat in. My dog eventually found the hoses and chewed through them though.. :x
1 - 6 of 6 Posts
