1 - 12 of 12 Posts
Discussion Starter #1
What spark plugs nd spark plug wires will work good on a MSD distributer i was thinking going wit 9mm wires but i dont know nd my motor is stock???
Ford racing wires are 9mm and im using them with a msd pro billet dist. But I forgot when I did my heads I switched to ngk coppers cuz for the head design I needed a "wider spark front"
Discussion Starter #6
I have a question my car didnt pass smog check they told me it needs a tune up but will the spark plugs nd spark plug wires will it help
Maybe, did they say anything else? Is your engine warming up fully? Check your timing. Any check engine lights?
You might not be getting full ignition if you're losing power. Check the power output at the alternator and Battery. Then maybe check spark plugs and move on from there.
1 - 12 of 12 Posts
