1 - 5 of 5 Posts
Discussion Starter · #1 ·
This speedo gear is from AOD, swapping in a T5. Was told could use the same gear just cut off 1/4" of shaft. Does anyone know the exact length of shaft on T5 speedo gear? Thanx in advance!
Why not just get an OE one from Latemodelrestoration?
---------- Post added at 05:58 AM ---------- Previous post was at 05:57 AM ----------
They are lik $12-15
Discussion Starter · #3 ·
Thats where I purchased this one from when I did the rear gear upgrade. Only difference is in color of gear & shaft length, teeth count is identical. If trim a bit off the shaft it'll be the SAME THING.... just need the appropriate shaft length.
1 - 5 of 5 Posts
