I have the same problem, I have a 2001 black convertible. I have sprayed WD40 behind the left tire on something, not sure what it is ( hey I am a woman) it seems to help. I have also sprayed some on the bolt that holds the seat in. My squeek is always on the left side behind me. Drives me crazy!!!yep i have same problem mine it is a 2001 i had it checked by 4 different mechanics all said it is just in the suspension nothing can be done, they checked the bushings, bearings, tie rod ends, controll arms , shock and struts all of it they all checked out ok, it has 67,000 miles on it so i dont know guess theres no fix for it , i used the white lithuim grease and wd40 and it quitened down but still has a small sqreach towards the back but thank goodness the front squeek is about gone, im gonna go in and spray towards the back underneith today see if that temporarly fixes the back as well,. its always beenthe left side, it doesnt do it on the right thats what i dont understand, for a while you could use the emergency brake while parked and it would go away for a bit but it always comes back.
ive talked to so many mechanics and mustang owners online and apparently there is no permenant fix for it.
if there is please let me know as long is its resonably affordable not like changing everything under there lol .
all help is appreciated.
Sandy
Anywhere you might thing there is a bushing or stress point just not on the barke dicks or around the pads.Also you might want to find something a bit better than WD40 even Hoppe's lube for firearms I think would work better.omg, glad i am not the only one. I have a 98 and mine has been squeaking for 4 years now, i have taken it in to many mechanics only to have them say they cant find it but then recommend i fix something else. Needless, i have spent tons on new shocks/ brakes/rotors, ugh,
so if i spray with WD40, where do i spray at? I am a female so i am unfamiliar with this kind of stuff but the noise is unbelieveably annoying and like everyone else it comes from the left side as well but now i tend to hear it from the right side....please help!!
Laura
