1 - 5 of 5 Posts
Discussion Starter · #1 ·
Im gettin the alternator whine through my system, it happened after I hit a bump and i've re-wired the system, got new signal cables, scraped the metal touchin the ground point and i'm still gettin the noise. I have the amps grounded just under the head rest, im nto able to take pix right now since i dont have a cam.
If you remove the head rest, you get 4 bolts goin across the top that hold the rear seat bracket in place, i have it grounded there, its touchin only metal. My question is where do you guys have your system grounded? Would you suggest a different spot?
i drive an f-150, so it'll be a little different.
i have my amp grounded to a bolt under my seat. the bolt is attached to the railed that my seat slides back and forth on.
I have mine grounded on the driver side in the trunk behind the little cardboard side panel. Nice little screw there for grounding in my 02 lol
1 - 5 of 5 Posts
