1 - 4 of 4 Posts
2002 Ford Mustang GT, TBoneHD32
After a drive of around 55 to 70 miles an hour for an extended period of 20 minutes or more. I put my car in reverse and there is a sound like rubber on metal, and I can feel the sound at the same time coming from rear of car. I replaced all pads, and rotors, and I know I have a leak at my differential pinion seal , but when I changed my diff cover I did not see any metal shavings in the fluid, the fluid did look frothy though. My car also shakes violently when driving between 60-65. I found that all my tires were severely under aired. Haven't driven far since adding air to tires. Pinion seal comes in next week some time. if i want to solve it by myself, does the tool FLY200 scanner can help me?
Any ideas?
Maybe transmission mount is broke or something. When u put in reverse, your tyranny moving a little bit. Maybe exhaust is loose.
Any ideas?
Did you ever get the pinion seal on? Have you drove it since you aired up the tire? Shaking between 60-65 could be your wheels aren't balanced. Maybe a bent rim. Not sure what the noise can be. Can you get a video of the sound it's making. Maybe try changing tranny fluid as well. Im not familiar with that scanner tool is. Is your car throwing a code though? If it is, you can get it scanned for free at most auto parts stores.
1 - 4 of 4 Posts
