1 - 5 of 5 Posts
Discussion Starter #1
I have been having alot of idle issues with my fox body lately. It started right after i installed a 70mm throttle body and egr sensor. My cars idle was all over the place and it would stall at every stop. I adjusted the egr sensor and it helped a little but it would still stall. Then I installed a 255lph fuel pump and the problem got even worse. The idle would surge the moment i start the car and alot of the time it would just shut off. Sometimes it wont start so id have to turn off the fuel pump and then start it. I dont know if its to much fuel since all i have done to my car is exhaust, throttle, and cold air. Do I need a tune to fix this? Any help would be apreciated.
Sent from my SM-N9005 using Mustang Evolution mobile app
I wasn't aware that it's possible to adjust the EGR sensor. Do you mean the Throttle Position Sensor?
Anyway, I think that you probably need to adjust the throttle body.
Will the engine run normally if you have your foot on the accelerator and are giving it some "gas"?
Discussion Starter #3
Yea sorry i mean the throttle position. Yes the car runs fine while im giving it gas and i did not notice any drop in power or hesistation only the idle
Yeah, apparently you have to adjust the throttle plates with the set screw on the aftermarket throttle bodies. They need to be set so that a little bit of air flows through when the plates are "closed".
There is a link to how to properly adjust a throttle body in one of our members recent posts... cliffyk. If you can't find cliffyk's link with a search, the information is probably online somewhere if you Google it.
1 - 5 of 5 Posts
