1 - 20 of 34 Posts
I've seen the pro springs and have the sport line springs so I would advise you go with the sportline package. You will also need caster camber bolts and adjustable panhard bar. Would strongly advise a set of lca's to if you have the money. Here is a picture of mine on sportlines.
Land vehicle Vehicle Car Motor vehicle Tire
The Blue Dragon
^ this. There are some companies moving away from many brands (ill leave the names out) and are moving towards konis. These are arguably the best dampers for street and road course mustangs
AmericanMuscle.com
I'm looking to purchase Eibach Mustang Pro-System-Plus (11-14 GT/V6) 35125.680 - Free Shipping!
Does anybody has any opinion on this kit? I also have a strut tower brace and want to know what else do I need to improve my handling? Thanks for you help
This is definitely a really nice kit! Like these guys said you can piece a nice kit together as well, they're both awesome options.
That's all your basic suspension mods in one kit, so you'll be good to go from there! I hope this helps. Please let me know if you have any questions or need some assistance! Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266. I can also have one of them call you directly.
-Dan
That, sir, is one beautiful Pony.
Discussion Starter · #8 ·
What's a difference between them two? Is the sport one lower than pro?
---------- Post added at 11:40 AM ---------- Previous post was at 11:39 AM ----------
Plus I have 295/30/20 in the back so I'm not sure how low I can go b4 it starts rubbing?
Thanks bro
---------- Post added at 11:29 AM ---------- Previous post was at 11:25 AM ----------
Yes te difference is the amour of drop. I live in South Georgia and routinely drive through savannah so the roads arnt great and I never have any trouble with how low my car is and I have a chin spoiler to. I will be running a set of the 20 inch staggered amr wheels this a summer once I wear out my tires and won't have any trouble rubbing
I have sportline springs, adjustable pan hard bar and eibach camber bolts as well. The tires are 275/35/19 and I def have wheel gap. I have a close up of the front wheel gap. It difficult to get some contrast with the pics when everything is black. Lol. The drop was 1.7 front 2.4 back. Sits relatively level with the back about a .25 inch higher than the front.
huh...that is interesting. I dropped the same as you 1.7 front and 2.4 back and I don't have nearly that big of a gap. I still have a gap, but not that big. Running 285-35-19 in the front and back.
how much did you cut your bumpstops?
The directions said not to cut them. Turns out though the nitro 275/35 are smaller in diameter than my stock Pirelli 245/45.
---------- Post added at 03:15 PM ---------- Previous post was at 03:14 PM ----------
It may be the angle of the pic too.
---------- Post added at 03:15 PM ---------- Previous post was at 03:15 PM ----------
Nitro lol. Nitto.
Nitro lol. Nitto.
That much of a drop...if you didn't cut them...you litter ally sit on the bump stops...
You need to cut them...the car with just the suspension loaded should not sit on the bump stops. Your car is sitting higher because of this and probably doesn't ride half as good as it can. My front bump stops after I cut them were literally about a half inch tall.
If you pull your struts back apart you'll find the bump stops are getting crushed. Also look at the back ones and the frame of the car will be sitting on them. I cut those down hell a far too.
Car us supposed to be supported by the springs and not by the bump stops.
The back bump stops were replaced with the supplied bump stops from eibach and my car rides quite well. I may take the struts apart again to see but the directions clearly state not to cut the front bump stops.
@nosympathy
I haven't had a chance yet to take the front struts off to check the bump stops yet but I want to ask about what you are using for camber and pinion angle adjustment.
I have camber bolts in the front. Haven't had time to get the alignment checked but I need to get the pinion back in line. Will LCA relo brackets do it or do I need an adjustable UCA to get it dialed in?
@nosympathy
I'll have to find the sheet I have it somewhere that shows my caster and camber angles. They are within fords specs. I just forget what. Just moved so might take me a few days.
As for pinion angle I still don't gave an adjustable UCA so it is still probably way bad. Yes you need a UCA to fix pinion angle. Only thing the LCA do is provide better traction.
@nosympathy
Camber bolts suck. I strongly recommend you Google "Camber Bolt Failure" and make your own decisions. Unless you're slammed the negative camber probably isn't that bad anyways.
Do you have camber plates? Or bolts?
Im 1.7 dropped in the front and my car is a DD. Definitely had to do some sort of adjustment hardware to keep from shredding the inside of the front tires. This is the reason I have the same size wheels and tires on all 4 corners.
I know there are a lot of brands of camber bolts out there. Has anyone here had issues with eibachs camber bolts?
1 - 20 of 34 Posts
