1 - 17 of 17 Posts
Discussion Starter · #1 ·
w00t w00t I just got my Xmas bonus from work... $300!!! Well... $277 after taxes, but close enough!
Anyways... one of the things I'm planning on doing after I get my tax return in January is of course new wheels and tires. But I had also planned to save money from now until then to get a suspension upgrade/kit for my car.
Well... now that I have nearly $300, that might be enough to get the new suspension now!!
I had looked at Steeda's Stage 1 kit (springs, caster/camber plates, and strut tower brace) which I believe goes for a little over $400 on the Steeda site. I guess what I'm more concerned with here is better handeling, cause quite honestly, Mustangs handle like crap!!
So what do you all think? Another important thing to consider is my body kit. My front bumper already sits very low to the ground, so I don't want to lower too much. I believe the Steeda springs are 1.0-1.25 inches. Is this correct?
And if anyone has any other recommendations, please let me know. :) Thank you!
Discussion Starter · #2 ·
http://www.stangsuspension.com/store/comersus_viewitem.asp?idproduct=275
What do you all think of that? For less than the Steeda kit... it seems to give soooo much more!
What's the quality like though? Cause these are supposed to be the same Ford parts put on the GT Bullits. Are these as good quality as something like Steeda or Eibach?
Quality wise they are pretty much the same in most aspects.
There are better dampers out there but tokico's aren't bad. Its a good starter suspension I'd say.
I would have to ask what kind of sway bars those were personally, might be just regular GT sways, in that case get a pair out of a junk yard for a lot less. Bullitt struts and shocks are probably better all around than MachIs because the Mach I is more for for Drag racing.
Contrary to popular belief on this and 3.8 for some reason, matched sway bars, in my humble opinion, are much superior to unbalanced ones, its much better to have front and rear sway bars that match than to have a v6 front bar and a GT or cobra rear bar. Take note of my mods list, both my sway bars are COBRA bars, not a cobra rear and a GT front bar.
I have shortened end links, and my cobra front bar is actually smaller than my GT bar was, but stiffer.
Cobra rear bars have to come off a 98 or older, the 99+ have IRS and won't work.
I agree with rick, to a point. Remember that these bars are 'matched' on
that car with that weight and they're also matched to give understeer.
I'd rather have a neutral or slightly oversteering car so I would get a
bigger rear bar. It all comes down to if you want under or oversteer and
what other mods you have. Throw in a panhard bar and you have to
change things around even more!
I third it !!!!!!!. I would also suggest looking into some C&C plates. after about 6 months I went back for a alignment check ( South Carolina roads are not the best) and they need further adjustment on the alignment and there was no more to adjust I now have UPR Shark Billit C&C Plates.
1 - 17 of 17 Posts
