1 - 6 of 6 Posts
Discussion Starter · #1 ·
Hello.. I have a 97 cobra. Motor is stock. Have o/r x pipe with no cats. I have a check engine light on, code is p1074 bank 2 system to lean. I have replaced mas airflow sensor, coolant temp sensor, intake gaskets. And im still getting the same code. (note).. if i dont let the car warm up for a few minutes first thing in the morning it will fall on its face before i get half a block down the road and wants to die.. Once it warms up it runs fine for the rest of the day.. Thank you
Discussion Starter · #3 ·
I was told when i bought it that it did have mil eliminators on it.. I havent actually gotten under the car to check. Reason being i was told that 02 sensor would not throw that code???
Discussion Starter · #5 ·
I wiill check.. I was just thinking, if they wernt on there then i would imagine i would have a code for bank 1 and 2 right? and could it be the front sensor as well that just may have went bad? were you having the same problem i mentioned about the car running terrible until it warms up? it will idle fine its just taking off when its cold is when it wants to die?
I'm not sure if both codes would come up or not. When I got my car it ran fine just really rich. But I also have other mods to. The guy that had it before me installed the mil eliminators on the front o2s instead of the rear so they did nothing at all. I have 2 sets because I didn't know he had em on there.
1 - 6 of 6 Posts
