1 - 3 of 3 Posts
Discussion Starter · #1 ·
My throttle idle adjusting screw is backed away from my throttle and not touching each other and I'm idling at 1050rpms. What does y'alls look like? Even though mine is trickflow 75mm I'm sure it should go back farther. I believe my blade is bent back can't see by the naked eye. I did a smoke down test and the only place it came through was through the blade which I figured was because of the idle screw set at but it was backed out when I tried to tune the idle int to .34 through the adjust screw.
I wonder if the nitrous explosion might have bent something?
There's definitely something wrong. The throttle stop should be resting on the set screw.
And it would be normal for some smoke to leak from the throttle body during a smoke test.
1 - 3 of 3 Posts
