1 - 20 of 41 Posts
Discussion Starter #1
trying to decide my next mod, im steering more towards the UDP just because i have heard people having problems with the TB. but i want your opinions! Anyone who has either i want to know what you think!
Udp only help above 4000 or 4500 rpms. TB would help throttle response sooner than udp kick in. I got steeds udp but rarely take my car above 4000 rpms. But I got em new for $71 on eBay. If u go with udps, watch eBay.
Got about 4 RWHP and ever little bit of RWHP you can get out of your motor is worth the money IMHO
Seriously you dyno'd after just a TB install?
If so what RPM or range did you realize this gain?
Curious now..
Unless you have enough mods that your sucking more air to your motor then your stock throttle body can handle, a throttle body wont do anything. It can actually hurt performance because air doesnt move as fast through the wider space if it is wider then you intake anyways.
Discussion Starter #9
That's a deal! I have a bone stock internal and my mods are stated in my signature. Nothing that would really help the flow drastically
03Sixtang said:
Could someone explain to me what a UDP is? I don't know what it stands for and curious as to what it does.
Under Drive Pulleys
---------- Post added at 02:38 PM ---------- Previous post was at 02:36 PM ----------
Under drive pulleys are a waste, when I had my car dynoed the speed shop took my under drive pulleys off and put my stock ones back on!
Get the throttle body!
---------- Post added at 02:38 PM ---------- Previous post was at 02:38 PM ----------
Curious now..
+1
Ye that's why I got em. Just keep watching and you'll find a set for cheap. The money u save on them is a gd start for TB mod fund. It takes time unless your filthy rich lol.
Discussion Starter #14
So now I'm confused I have heard both opinions saying the other one is useless and a waste haha
Underdrive Pulleys are a universally accepted good modification, I dont know what happened with yours White Cobra. Less power to accescories=more power tp the wheels. Just like using your AC draws power.
I think the problem with me was a cooling issue , the UD water pump pulley is bigger so I think that's why they switched me back to stock!!
I just used my steeda crank pulley. They advertised them for 96-01. Well they were for 01-04. So I used crank and bought smaller belt.
Discussion Starter #19
Could you guys feel any difference in butt dyno or fuel mileage? I think imgoing with a udp set that has multiple, instead of just the crank
UFOs come in 3 pulleys. Some come in 2, crank+alt. The only reason I only used just crank was cause they were wrong year. Ford changed water pump pulley in 01. So it was that or nothing. Ill eventually put others on. I just have to get right water pump pulley. Its prob going to b awhile lol.
PS. Stay clear of the piggyback style. I've read lots of bad stories.
1 - 20 of 41 Posts
